Thread lama ditutup, karena mungkin isinya udah nggak terlalu relevant lagi, salah2 bisa bikin sesat folder baru
Bagi yg ingin posting di sini, selain spek hardware, mohon sertakan info full load temp, PPD yg didapat beserta project yg sedang digiling.
Lebih baik lagi kalau ada SS fahmon atau sejenisnya dan foto dari rig yg dipakai. Foto yg punya rig nggak gitu penting, kecuali bagi yg merasa dirinya cakep, boleh deh ikutan nampang
Semoga thread ini bisa jadi panduan bagi yg mau beli hardware baru (e.g. ajang saling meracuni)
Happy folding!
Data 2009
VGA
Palit 9600 GSO Sonic Edition by roedzzz
PPD: 5,249 (p5506)
Full load temp: 71 C
POV GTX 260 (216 Core) by GuardianArmy
PPD: 8,027 (p????)
Full load temp: 64 C
POV 9800 GTX+ by GuardianArmy
PPD: 5,604 (p????)
Full load temp: 54 C
ZOTAC 9800 GTX+ by extreme_comp_jogja
PPD: 6,099 (p5015)
Full load temp: 66 C
HIS HD4850 IceQ 4 X2 by extreme_comp_jogja
PPD: 7,041 (p4742)
Full load temp: 67 C
Dual HIS HD4830 by extreme_comp_jogja
PPD: 6,051 (p4744) (updated)
HIS HD4870 Turbo 512MB DDR5 by extreme_comp_jogja
PPD: 4,190 (p4742)
Full load temp: 65 C
HIS HD4850 ICEQ-4 Turbo X by extreme_comp_jogja
PPD:3,818 (p4744)
Full load temp: 58 C
POV 9800GTX+ 1GB by roedzzz
Default:
PPD:5,439 (p5763)
OCed:
PPD:5,623 (p5763)
Full load temp: 69 C
Zotac Gtx 280 Amp Edition by extreme_comp_jogja
Default:
PPD:8,092 (p5762)
OCed:
PPD:9,242 (p5766)
38608 Folders' PPD Info:
Palit 9600 GSO 384mb (GRiffiN)
PPD: 4,365 (p5800)
Sparkle 9800 GT 512mb (GRiffiN)
PPD: 4,822 (p5506)
Full load temp: 56 C
PowerColor 4850 512MB (g4ndr1k)
PPD: 2835 (4744) (Q6600@2.8 GHz) - 3199 (Q6600@3.2 GHz)
Full load temp: 57 C (tt duo orb)
Asus 9800GT (ferry_g)
PPD: 5,057 (p????)
Full load temp: 76 C
XFX 8800GT XXX (acilmut)
PPD: 5,681 (p5506)
Full load temp: 55 C (tt duo orb)
Manli 9800GTX+ (hongo takeshi)
PPD: 6,284 (p5016)
Full load temp: 62 C
Asus EAH4850 (ferry_g)
PPD: 2,785 (p????) (Q6600@2.4 GHz)
Full load temp: 75 C
Eagle 9800GTX (AnkLrG)
PPD: 5,760 (p5016)
Full load temp: 63 C
Biostar 8800GT (Think)
PPD: 4,712 (p5014)
Asus EN9600GSO (ferry_g)
PPD: 5,317 (p????)
Multiple GPU, 2 VGA DA Sonic 9600 GSO 384 Mb, di DFI UT mobo, open case, with just AMD X2 3600 (agung_y dan agung_y)
PPD: 5,250 + 5,250 (p5015 + p5013)
Full load temp: pokoke adem banget liat sendiri napa? tinggal klik aja linknya...
Asus EN9600GT (ferry_g)
PPD: 3804 (p????)
Full load temp: 74 C
HIS 4870 (roedzzz)
PPD: 3,788 (p4743) (E8400 4,080 MHz, 582 x 7)
Full load temp: 84 C
XFX 8800GT 512MB (t370)
PPD: 5,751 (p5014)
Full load temp: 45 C
ECS 8800GT-512MX (anno78)
PPD: 5,758 (p5016)
Asus 9800GTX+ (ferry_g)
PPD: 5,924 (p????)
Manli 9800GTX+ (Intel vs AMD)
PPD: 6,912
MSI 9800GTX+ (AnkLrG)
PPD: 6,380 (p5013)
Full load temp: 68 C
Manli 8800GTS (schumizt)
PPD: 5,681 (p5016)
9600GT (iqbalimoet)
PPD: 3,575 (p5013)
Asus 9800gtx+ dk (ferry_g)
PPD: 6,380 (p????)
2 x Winfast 9600GSO Extreme (rafael)
PPD: 10,304 (p5800)
Full load temp: 60 C (Zalman)
2 x Palit 9600GSO Sonic (g4ndr1k) PPD: 7,498 (p5760)
Full load temp: 61 C (ruangan AC plus disembur pakai kipas 12cm di atas VGA)
HIS HD4870 Turbo + HIS HD4830 (extreme_comp_jogja)
PPD: 7,263 (p4743) (E8400 4,000 MHz, 500 x 8)
Full load temp: 56 C & 59 C (respectively)
HIS HD4870 Turbo + HIS HD4850 Turbo X (extreme_comp_jogja)
PPD: 7,606 (p4742) - (E8400 4,160 MHz, 520 x 8)
Full load temp: 67 C & 57 C (respectively)
POV 280GTX (extreme_comp_jogja)
PPD: 8,132 (p5506)
9800GX2 (G-hosT)
PPD: 9,348 (p5760)
Full load temp: 87 C
BIOSTAR 9600GT OC Edition 512mb 256bit DDR3 (alpony_sz)
PPD: 3,703 (p5014)
Full load temp: 56 C (pakai kipas 60cm)
Dual Gigabyte GV-N26OC-896H-B (ferry_g)
PPD: 12,765 (p5760)
ASUS Rampage II Extreme
Intel Core i7-920
Corsair 3 channel 6 GB kit PC 10666
3x Gigabyte GTX260 GV-N26OC-896H-B (181.20)
Coolermaster RS-A00-EMBA 1000 watts
by ferry_g
PPD: 19,516 (p5760)
Full load temp: 57 to 64 C
ZOTAC 9800GT AMP (u84n)
PPD: 4,483 (p5761) ; 5,648 (p5770)
Full load temp: 79 C
ASUS GTX 285 (ferry_g) updated!
PPD: 8,294 (p5763)
285 Threesome (ferry_g)
PPD: 24,488 (p5764)
VGA Manli 9800GX2 (OC'ed) (budirahmat)
PPD: 12,449 (p????)
Full load temp: 92 & 87 C
DA GTX 295 (budirahmat)
Performance tiap GPU ~ Project :
P.5749 ; Credit.511 : 6.398,61
P.5900 ; Credit.420 : 8064, 61
p.5760 ; Credit.384 : 8.294,40
P.5766 ; Credit.353 : 8.714,06 [Total PPD. 17.528,12]
Full load temp: 65 & 66 C
FI LP-UT X48 T2R, C2Q 9450,DDRII 6GB,DA GTX295 (budirahmat)
Untuk menghangatkan suasana, sedikit update :
DFI LP-UT X48 T2R, C2Q 9450,DDRII 6GB,DA gtx295 --> PPD 23.758,58
PPD GPU Total : 19.615,14 (PPD 9807,57 per GPU, pada P.5900 ; credit 420)
PPD CPU-SMP Linux64 bit : 4. 143,44 (PPD 2071,72 per CPU, pada P.2653 ; credit 1760)
GPU0 : 65C, GPU1 : 67C, CPU : 47C
Fan GPU : 100%
GTX275 (a603nk)
PPD: 6,132 (p5749)
Full load temp: 73 C
Q9550@3.6, GTX295@576/1512/999 (froster)
Total PPD: 21.277
GPU1: P5773
GPU2: P5759
SMP1: P2669 (ubuntu via vmware)
SMP2: P2669 (ubuntu via vmware)
GPU Temp: 81 C
VGA : Digital Alliance Geforce GTS 250 Green Edition 512 Mb DDR3 256 bit (mirza_pku)
PPD : 5446 Project : 5771 (R8, C161, G808)
GPU Temp :680 C @ Fan speed 54%
Data 2010
khurios2000
-bigadv i7 920 4Ghz -smp 8 tanpa bonus
Project : 2681
Core : SMP Gromacs CVS
Frames : 100
Credit : 25403
-- i7 920 4Ghz --
Min. Time / Frame : 30mn 33s - 11973.92 ppd
Avg. Time / Frame : 32mn 41s - 11192.35 ppd
Project : 2683
Frames : 100
Credit : 25403
-- i7 920 4Ghz --
Min. Time / Frame : 30mn 32s - 11980.45 ppd
Avg. Time / Frame : 36mn 42s - 9967.39 ppd
Cur. Time / Frame : 32mn 06s - 11395.74 ppd
R3F. Time / Frame : 32mn 06s - 11395.74 ppd
Eff. Time / Frame : 39mn 22s - 9292.21 ppd
P10101 berbagai jenis video (9600GSO, 8800GT dan GTX 260)
Code:Project : 10101 Core : GPUv2 Gromacs Frames : 100 Credit : 548 -- 8800GT-1 -- Min. Time / Frame : 1mn 53s - 4190.02 ppd Avg. Time / Frame : 1mn 53s - 4190.02 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 8800GT-2 -- Min. Time / Frame : 1mn 53s - 4190.02 ppd Avg. Time / Frame : 1mn 53s - 4190.02 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 8800GT-2 -- Min. Time / Frame : 1mn 55s - 4117.15 ppd Avg. Time / Frame : 1mn 55s - 4117.15 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 8800GT-4 -- Min. Time / Frame : 1mn 53s - 4190.02 ppd Avg. Time / Frame : 1mn 53s - 4190.02 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-1 -- Min. Time / Frame : 2mn 10s - 3642.09 ppd Avg. Time / Frame : 2mn 10s - 3642.09 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-2 -- Min. Time / Frame : 2mn 13s - 3559.94 ppd Avg. Time / Frame : 2mn 13s - 3559.94 ppd Cur. Time / Frame : 2mn 14s - 3533.37 ppd R3F. Time / Frame : 2mn 14s - 3533.37 ppd Eff. Time / Frame : 2mn 15s - 3507.20 ppd -- 9600GSO-3 -- Min. Time / Frame : 2mn 13s - 3559.94 ppd Avg. Time / Frame : 2mn 13s - 3559.94 ppd Cur. Time / Frame : 2mn 15s - 3507.20 ppd R3F. Time / Frame : 2mn 14s - 3533.37 ppd Eff. Time / Frame : 2mn 14s - 3533.37 ppd -- 9600GSO-4 -- Min. Time / Frame : 2mn 13s - 3559.94 ppd Avg. Time / Frame : 2mn 13s - 3559.94 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-1 -- Min. Time / Frame : 1mn 06s - 7173.82 ppd Avg. Time / Frame : 1mn 07s - 7066.75 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-2 -- Min. Time / Frame : 1mn 05s - 7284.18 ppd Avg. Time / Frame : 1mn 25s - 5570.26 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-3 -- Min. Time / Frame : 1mn 06s - 7173.82 ppd Avg. Time / Frame : 1mn 06s - 7173.82 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-4 -- Min. Time / Frame : 1mn 06s - 7173.82 ppd Avg. Time / Frame : 1mn 06s - 7173.82 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame
P577x (9600GSO, 8800GT dan GTX 260)
Code:Project : 5770 Core : GPUv2 Gromacs Frames : 100 Credit : 353 -- 8800GT-1 -- Min. Time / Frame : 51s - 5980.24 ppd Avg. Time / Frame : 51s - 5980.24 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 8800GT-2 -- Min. Time / Frame : 51s - 5980.24 ppd Avg. Time / Frame : 52s - 5865.23 ppd Cur. Time / Frame : 55s - 5545.31 ppd R3F. Time / Frame : 54s - 5648.00 ppd Eff. Time / Frame : 53s - 5754.57 ppd -- 8800GT-2 -- Min. Time / Frame : 51s - 5980.24 ppd Avg. Time / Frame : 51s - 5980.24 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 8800GT-4 -- Min. Time / Frame : 51s - 5980.24 ppd Avg. Time / Frame : 51s - 5980.24 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-1 -- Min. Time / Frame : 1mn 11s - 4295.66 ppd Avg. Time / Frame : 1mn 11s - 4295.66 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-2 -- Min. Time / Frame : 1mn 10s - 4357.03 ppd Avg. Time / Frame : 1mn 10s - 4357.03 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-3 -- Min. Time / Frame : 1mn 14s - 4121.51 ppd Avg. Time / Frame : 1mn 14s - 4121.51 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 9600GSO-4 -- Min. Time / Frame : 1mn 13s - 4177.97 ppd Avg. Time / Frame : 1mn 13s - 4177.97 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-1 -- Min. Time / Frame : 34s - 8970.35 ppd Avg. Time / Frame : 34s - 8970.35 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-2 -- Min. Time / Frame : 34s - 8970.35 ppd Avg. Time / Frame : 34s - 8970.35 ppd Cur. Time / Frame : 35s - 8714.06 ppd R3F. Time / Frame : 35s - 8714.06 ppd Eff. Time / Frame : 33s - 9242.18 ppd -- 260-c216-3 -- Min. Time / Frame : 35s - 8714.06 ppd Avg. Time / Frame : 35s - 8714.06 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame -- 260-c216-4 -- Min. Time / Frame : 35s - 8714.06 ppd Avg. Time / Frame : 35s - 8714.06 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame
Think
VGA Biostar GTS 250 512MB DDR3
P5765 - P5772 (Credit 353)
HiddenCode:Core : GPUv2 Gromacs Frames : 100 Credit : 353 -- GTS250 -- Min. Time / Frame : 46s - 6630.26 ppd Avg. Time / Frame : 46s - 6630.26 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame
P5793 - P5797 (Credit 787)
HiddenCode:Core : GPUv2 Gromacs Frames : 100 Credit : 787 -- GTS250 -- Min. Time / Frame : 2mn 00s - 5666.40 ppd Avg. Time / Frame : 2mn 00s - 5666.40 ppd No Cur. Time / Frame No R3F. Time / Frame No Eff. Time / Frame
P5906 (Credit 472)
HiddenCode:Core : GPU2 NV MT Frames : 100 Credit : 472 -- GTS250 -- Min. Time / Frame : 58s - 7031.17 ppd Avg. Time / Frame : 1mn 11s - 5743.77 ppd Cur. Time / Frame : 1mn 23s - 4913.35 ppd R3F. Time / Frame : 1mn 18s - 5228.31 ppd Eff. Time / Frame : 1mn 18s - 5228.31 ppd
P5912 - P5915 (Credit 1888)
HiddenCode:Core : GPU2 NV MT Frames : 100 Credit : 1888 -- GTS250 -- Min. Time / Frame : 4mn 30s - 6041.60 ppd Avg. Time / Frame : 4mn 48s - 5664.00 ppd Cur. Time / Frame : 5mn 02s - 5401.43 ppd R3F. Time / Frame : 5mn 01s - 5419.38 ppd Eff. Time / Frame : 5mn 13s - 5211.60 ppd
P10101 (Credit 548)
HiddenCode:Core : GPUv2 Gromacs Frames : 100 Credit : 548 -- GTS250 -- Min. Time / Frame : 1mn 33s - 5091.10 ppd Avg. Time / Frame : 1mn 33s - 5091.10 ppd Cur. Time / Frame : 1mn 42s - 4641.88 ppd R3F. Time / Frame : 1mn 42s - 4641.88 ppd Eff. Time / Frame : 1mn 37s - 4881.15 ppd
