Skype integration
You may now enter your Skype username, in addition to AIM, ICQ, MSN, and Yahoo. Calls, chats, and more may be initiated through vBulletin.
Click here for more info
Natural language search improved
Natural language search (using MySQL's fulltext engine) should now return more relevant results, particularly when searching in a limited number of forums.
Getnew/getdaily now return threads in forums with "Can View Thread Content" set to no
These thread titles will now appear when clicking "New Posts" or getting posts in the last 24 hours.
IP banning is much improved
IP banning is now much more accurate when dealing with incomplete octets. Additionally, you may now use * as a wildcard at any place in the IP address.
Administrators may leave users' emails blank
Even if unique email addresses are required, administrators may make any number of users' emails blank to prevent mail from being sent to them.
Yes/No radio buttons changed back to horizontal orientation
The line break added between the yes and no options in the admin control panel has been removed. Yes/no rows will now look as they did in previous versions.
