Hubungan Shutter Speed & Aperture & ISO - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
Thread: Hubungan Shutter Speed & Aperture & ISO
    Jkt
    Re: Hubungan Shutter Speed & Aperture & ISO
    Quote Originally Posted by yossie3660 View Post
    Yup...aku juga pake mode P ini biar lebih simple karena susah didapatkan settingan pake M atau Av...alhasil beberapa kali percobaan maen di P dengan atur2 dikit dan dapetlah yang sesuai.....dikasih flash dengan sekian kompensasi masih aja efek bayangan dan terlalu silaunya....yah gitu deh...kudu coba2 pula demi mendapatkan hasil yang baik..
    Metering emang aga beda antara make flash n ga,
    Kl make flah, metering jg beda antar mode P, Av, M di canon, kl nikon gw kurang tau
    Gw ada "bahan bacaan mengenai metering flash tp dlm inggris
    Program (P) mode flash.
    The overriding principle of Program (P) mode in flash photography is that the camera tries to set a high shutter speed so that you can hold your camera by hand and not rely on a tripod. If that means the background is dark, so be it.
    Program mode operates in one of two modes, depending on the ambient (existing) light levels.
    1) If ambient light levels are fairly bright (above 13 EV) then P mode assumes you want to fill-flash your foreground subject. It meters for ambient light and uses flash, usually at a low-power setting, to fill in the foreground.
    2) If ambient light levels are not bright (below 10 EV) then P mode assumes that you want to illuminate the foreground subject with the flash. It sets a shutter speed between 1/60 sec and the fastest X-sync speed (see above) your camera can attain. The aperture is determined by the camera’s built-in program.
    Because the camera tries to keep the shutter speed at a reasonable speed for handholding the camera you will end up with dark or black backgrounds if you take a flash photo in P mode when ambient light levels are not bright.
    On most if not all EOS cameras, P mode is not shiftable when flash (internal or shoe-mounted Speedlite) is used. Note also that DEP mode cannot work correctly with flash - its metering settings basically revert to P mode if you try it.
    Av (aperture priority) mode flash.
    Av mode lets you set the depth of field by specifying the lens aperture. The camera then chooses a shutter speed ranging from 30 seconds to the camera’s X-sync speed, in order to expose the background correctly. If that means the shutter speed is some really low value so that you need to use a tripod to avoid camera-shake blur, so be it. In dark conditions, therefore, Av mode works in slow sync mode.
    Flash duration (flash output) is determined by the flash metering system. Like Tv mode the camera always works in fill flash mode when in Av mode.
    There is one exception to this. A number of EOS cameras have a custom function you can set to ensure that the shutter speed in Av mode when using flash is locked to the X-sync speed. The EOS 10/10s and Elan II/EOS 50, for example, have such a custom function, which lets your camera behave more like P mode when in Av mode. However this custom function will only lock the camera to X-sync in Av mode and will not choose a shutter speed from 1/60 sec to X-sync, the way P mode does.
    As always, the camera will prevent you from exceeding its built in X-sync speed unless FP mode is available to you and engaged. If the shutter speed value of 30" flashes in the viewfinder then there isn’t enough light to expose the background correctly and you’ll need a larger aperture or faster film. If the camera’s X-sync flashes in the viewfinder then you’ll need to decrease the lens aperture, engage FP mode if it’s available or use slower film.
    Manual (M) exposure mode flash.
    In manual exposure mode you specify both the aperture and shutter speed, and your exposure settings will determine how the background (ambient lighting) is exposed. The subject, however, can still be illuminated by the automatic flash metering system since the flash can automatically calculate flash output levels for you. This is a marked contrast to the olden days, when photographers would carry around little flash exposure tables with them in order to work out manual flash settings.
  2. #22
    Quote Originally Posted by yurisr View Post
    The overriding principle....
    Av mode lets you set the depth of ....
    Manual (M) exposure mode flash.......
    Pake bahasa susah sihh.............
    Sederhananya SLR itu biasanya punya mode :
    Manual
    Auto
    P(Program)
    Aperture Priority
    Shutter Priority
    Dan ada tambahan Preset seperti Sport,panoramic dll.
    Ada juga SLR yang menambahkan "Scene" mode
    • Manual : Segalanya manual
    • Auto : Kamera akan menset exposure terbaik berdasarkan hasil "pengindraan" kamera, walaupun auto perhatikanlah setting meteringnya, metering menentukan bagaimana kamera membaca keadaan pencahayaan, pilihannya beragam tergantung SLRnya :
      • Auto metering atau Average, adalah mengukur cahaya diseluruh frame
      • Spot metering hanya "spot" saja..berguna untuk mengukur pencahayaan di sebgian kecil frame misalnya mengukur di daerah muka/orang saja
      • Spot metering "backlight", mungkin tidak semua SLR punya ini, berguna untuk foto dengan background yang lebih terang, sehingga hasilnya tidak gelap pada objectnya.
      • SPot metering shadow..kebalikan backlight....Sorry istilahnya mungkin terbalik(backlight dan shadow) dan berbeda di masing2 slr.
      • Kalo gak salah 350D meteringnya dengan mebuat kotak di frame secara bebas/manual, tidak spot metering.
    Memakai auto kadang2 membuat setiap gambar yang berbeda menjadi tidak seragam tingkat exposurenya. PAda auto, bila flash dalam keadaan auto akan otomastis bekerja bila dirasa(oleh kamera) pencahayaannya kurang, kecuali flashnya di matikan, maka kamera akan merubah shutter speed jadi lambat atau bila ISO nya auto akan menset ISO tinggi.
    • Program....sebedarnya suatu preset. Kamera akan menentukan nilai2 parameter standar dengan membaca pencahayaan yang ada, tetapi berbeda dengan Auto, Program mempertahankan Shutter speed tidak terlalu lambat. Tidak memerintahkan Flash bekerja bila dalam keadaan tertutup, walaupun flashnya auto.
    • Aperture priority : kita di beri kebebasan menset aperture. Sekali kita tentukan aperturenya maka parameter2 lain(shutter speed, dan ISO bila ISOnya auto) akan mengikutinya untuk mendapatkan exposure terbaik,
    • Shutter priority : Sama seperti Aperture priority, tetapi yang diset adalah Shutter speednya...aperture yang mengikuti secara auto, termasuk ISO bila ISOnya diset AUTO.
    • Preset...ini sih di Poket camera juga ada...
    • Scene...juga ada di prosumer.....
    Oh ya...selain Manual, semua mode itu diperlukan pemilihan metering yang tepat seperti yang dijelaskan pada poin 2(auto)
    Dalam prakteknya...gue lebih sering pake Aperture priority, Manual dan Program.... pada situasi :
    Aperture priority bila gue dihadapkan pada situasi "jumlah orang" yang berbeda dan "jarak" yang berbeda..agar gue bisa menentukan berapa kira2 DOFnya.
    Manual.....Bila cahaya disekeliling gue konstant seperti outdoor dan lebih untukk candid ketimbag foto rame2.
    Program...palng nyaman untuk liputan wedding, segalanya serba tidak menentu..biar kamera yang mikir, bukan gue...
    Yahhh itu teknik bego-begoan gue aja.......kalo dah jago akan pake manual terus kali yach........
    Siapa Bilang Urang Sunda gak bisa ngomong F....itu PITNAH !!!
    CARA mencetak foto dengan komposisi terbaik sesuai keinginan : KLIK : http://forum.chip.co.id/olah-digital...ml#post1334479
  3. #23
    Jkt
    Heheheh, om ara dah pake bhs yang gampang
    Nambahin dkt aja, perbedaan metering di P n Av sebenernya buat metering backgroundnya aja CMIIW.
    Kl di mode P, yg di"meter" foregroundnya aja, kamera biasanya set aperture di bukaan terbesar lensa, trus speed nyesuaian, tp ada limitnya, kl di canon sih kl ga salah speed paling lambatnya 1/60 CMIIW, jd misal dengan f stop 2.8 trus speed dpt 1/60, background nya gelap ya tetep jadi gelap, soalnya di mode P yg dimeter dominan foregroundnya.
    Beda kl di mode Av, background jd di"meter" ma kameranya, misal kl set fstop 2.8, nah kemarenya tetep metering background buat ngitung speed dpt brapa, kl dpt speednya 10 detik ya dia set speed ampe 10detik biar backgroundnya ga gelap, foregroundnya diatur ma metering flash, brapa kuat cahaya flashnya, dengan catatan ETTL nya aktif yah
    Btw, gw sering pake mode manual kl pake flash tp ETTLnya aktif
  4. #24
    Nov 2007
    jakarta, kelapa gading
    mantab nich treath nambah pengetahuan gw banget yang baru belajr.
    thanks to all
  5. #25
    Hihihihi.kamera gue beda yach sama kamera loe.......punya gue bisa di set meteringnya walaupun dalam P mode...jadi Mode(P,A, Dll...) adalah hal yang terpisah dengan Metering...Kalo susah dapet muka yang terang tinggal pilih spot metering aja....yang di "meter" cuma mukanya aja, tetapi bila backgrounnya terlalu terang pilih yang Spot yang lainnya
    Thx
  6. #26
    Jkt
    Quote Originally Posted by ara View Post
    Thx
    Hehehehe, punya gw jg bs diset metering multi, average n partial (tp ga ada spot )
    Maksud gw bukan metering itu om ara, tp metering flashnya. Kl di mode P, kl backgroundnya gelap, speednya ga akan lebih rendah dr 1/60 detik kl dikamera gw, jadinya foregroundnya exposurenya "normal" tp backgroundnya gelap. Kl flashnya dinyalain yah, kl flashnya dimatiin yah normal2 aja meteringnya. Itu yg gw pelajari di canon, mungkin di nikon or yg laen beda yah cara metering flashnya???
    beda kl di mode Av, dikamera saya, br mau speed dibawah 1/60 detik buat "menangkap detail background yg gelap kl flashnya dinyalain.
    Btw, dimode M jg ga sepenuhnya manual, kecuali ETTLnya di matiin, gw biasanya set manual fstop n speednya tp flash msh ETTL jd exposurenya yg ngatur flashnya
  7. #27
    Sebenernya SLR sama aja...cuma kita berdua sama bego kali yach.....
    Kalo latar belakang gelap dan depan juga gelap ...dan kita mau ambil terang semua(latar belakang bukan terang sekali tetapi terdefinisi dengan baik bukan blackout)...maka ada teknik lain lagi tuh.....misalnya mau memfoto malem hari dan pemadangan dibelakangnya(misalnya rumah yang ada sekian belas meter dibelakang) tetep kelihatan bagus dengan lampu2 penerangan yang temaram terlihat baik.....maka diperlukan "Slow" flash...secara tekniknya gue bingung mengungkapkannya...intinya Shutter terbuka lebih dahulu dari Flash.... bodohnya begini >>> Shutter terbuka lambat.....gambar terekam sehingga latar belakang(juga depan) terekam dengan baik...lalu sesaat sebelum shutter menutup Flash menyala untuk memperjelas Foreground...
    Hampir sama tekniknya bila memfoto orang dengan latar belakang gemerlap lampu2 kota...orangnya jelas tetapi gambar lampu2 hotel/gedung2 bertingkat tercapture baik.
    Juga bisa dipakai untuk mobil yang bergerak pada malam hari tertangkap gambarnya dengan baik tetapi Lampu belakang mobilnya terlihat seperti "terseret"/trail
    jelas harus pake Tripod...................
  8. #28
    Jkt
    Hahahaha, kyknya gw yg bego deh
    Nah itu dia maksud gw, slow sync , kl di canon setau gw ga bs pake slow sync kl di mode P (paling lambat 1/6 detik), hrs di mode Av br bs slow sync heheheheheh, duh bego yah gw
  9. #29
    Yaaayayayaya....itu dia namanya Slow Sync......besok gue post yach foto2 slow sync nya.........
    Kalo P terima beres aja kali yach..............
  10. #30
    Jkt
    Iya kl di P, speednya paling rendah di 1/60 di canon buat menghindari shake, kl di oly gw kurang tau brapa speed plg lambatnya
