Quad 11LA active speaker = worthed ??? - Page 2
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 11 to 20 of 99
Thread: Quad 11LA active speaker = worthed ???
    Re: Quad 11LA active speaker = worthed ???
    Quote Originally Posted by Edmondtandra View Post
    lebih bagus ampli terpisah bro dijamin.. mendingan beli quad 11L + ampli..
    gak mampu secara ekonomis bro buat nebusnya ... quad 11L2 3,5jt sisa 1jt doang ... mana bisa buat nebus amplifier belom kabel2nya
  2. #12
    under the mistletoe..
    quad 11L2 3,1 jt... sisanya bisa buat gainclone bro..
  3. #13
    bisa nanya lagi bro ... yg ini bagus gak ampli Gcnya kira2
    thanks a lot
  4. #14
    Jul 2009
    Bali
    sorry oot... klo epos ama quad worth mana bro? epos m5i ama m12.2 jauh bgt ya bedanya? sorry oot...
  5. #15
    Quad 9LA USB DAC Active Monitors
    Specifications
    Amplifier Power: 60w per speaker
    Dransducer Complement: 2 Way
    Cone Bass Driver: 4" (100mm)
    Soft Dome Tweeters: 1" (25mm)
    Frequency Response: 50Hz-21KHz
    Short-term peak SPL: 105dB
    Dimensions: 248 x 152 x 237mm
    Weight:
    5.30
    Features
    Fully Amplified Monitors
    Magnetically Shielded
    Master and slave speaker
    IR Remote Control: +/- Volume, Mute, Source Select
    USB DAC
    Optional Table Stand Available
    3.5mm Stereo Input on front of speaker
    15mm MDF ported enclosure
    RCA Stereo Phono input on rear of speakers
    IEC Mains Power Connector
    Based on the highly successful Quad 11L and 11LAspeakers the little brother 9LA is a active 2 way speakercontaining 60w amplification in each speaker, along with an internal USB DAC for use as a high end desktop speaker system. The 9LA also includes a 3.5mm input for use with iPods & other media players along with traditional RCA inputs for use with CD/DVD players TV's etc. The 9LA comes with a IR remote control for source selection & volume control.
    biar semakin memperkeruh suasana .... tambah asiik ada usb DAC ... langsung dari PC tanpa perlu beli SC mahal2
  6. #16
    Dec 2007
    Bogor
    mending terpisah..
    Pasif + Ampli..
    kalo ga cocok suaranya bisa di ganti satu2 sampai ketemu yang pas..
  7. #17
    Quote Originally Posted by annoep View Post
    mending terpisah..
    Pasif + Ampli..
    masalahnya diganti2 = over cost ... lagian yg ini dah dicombine sama pabriknya jadi kemungkinan mismatch kecil CMIIW
  8. #18
    чистилище
    kemungkinan mismatch kecil, kualitas suara kecil juga.
    kenyataan tentang orang indonesia:
    http://forum.chip.co.id/2696114-post12.html
  9. #19
    thanks a lot
    Hmmmm.... Bagus itu khan relatif. Kl d budget segitu mending cb cari seken2 nya NAD 320, marantz, denon atau ampli vintage yg lain (yg penting komponen msh original terutama trafo nya) soalnya tmn pny pengalaman GC d samain sm ampli branded jadul dgn watt yg lbh rendah suara msh lbh bagus (lbh kenceng gainnya, suara lbh soft) ampli jadul. GC ntr kl anda salah2 pilih speaker malah gk keangkat lho.
  10. #20
    Quote Originally Posted by Genzo_milano View Post
    wah ... mumpung ada master audio cable ...
    mo nanya bro kira2 kalo ane ambil quad 11LA ini kabel IC yg cocok pake apa yah dari asus xonar STX ke speaker ... gak usah yg bagus2 banget ... yg penting perf/pricenya paling bagus
    tadi seh ditawarin yg jual pake QED performance Audio 1 ... katanya bisa nambah performance sampe 30% betul gak sih??? ato ada kabel yg lebih cocok lagi RCA to RCA (max 500rebu ajah)
