Wah thanks infonya...
Ini gue copy paste dari web-nya, sapa tau ada yang butuh infonya...
VX2260wm
22" (21.5" viewable) widescreen with Full 1080p Resolution
Optimize your desktop Experience
Optimize your desktop experience with ViewSonic's Full HD 1080p 22" (21.5" viewable) VX2260wm widescreen LCD. Encased in a glossy black bezel, this monitor delivers beautiful HD images. Connect your game console or DVD player through the HDMI input and enjoy HD content on your desktop. High brightness, super-fast 2ms video response and ultra-high 20,000:1 dynamic contrast ratio deliver brilliant, blur-free images with incredible definition and detail. Completing the multimedia desktop experience are integrated stereo speakers with SRS WOW HD stereo sound. The Eco-mode function can save up to 40% on energy costs. The VX2260wm is ideal for the discriminating gamer or graphics professional who demands top-of-the-line images an performance.
MSRP: $270.00 US
Features
Widescreen aspect ratio with Full HD 1920x1080p resolution
The widescreen aspect ratio allows you to view HD content in its native format with no stretching or distortion.
20,000:1 dynamic contrast ratio Learn more about dynamic contrast ratio.
Provides for darker black levels and better overall front-of-screen performance.
Fast 2ms video response delivers superior picture clarity
OptiSync® digital/analog inputs
The digital HDMI input gives you the best possible connection to HD signals. Multi-mode input technology supports both digital (HDMI or DVI) and analog (RGB) inputs.
SRS WOW HD sound
Extends the speaker frequency range, delivering better response and sound performance.
Eco-mode conserves power
Environmentally-friendly Eco-mode reduces power consumption and extends backlight life.
Aspect ratio adjustment
Eliminates image distortion by maintaining correct image proportions for both widescreen and native 4:3 content.
Stylish slim-bezel design with glossy piano-black finish
The thin bezel lets you see more without taking up valuable desktop real estate. The floating head design accentuates the visual experience.
Specifications
LCD Type 21.5 wide Color TFT Active Matrix LCD Display Area 18.7" (H) × 10.5" (V) / 21.5" diagonal Optimum Resolution 1920x1080 WUXGA Brightness 300 cd/m2 (typ) Contrast Ratio 1000:1 (typ.) ; 20000:1 dynamic Viewing Angle 170° horizontal, 160° vertical Response Time 5ms (typ); 2ms (gtg) Pixel Pitch 0.248mm Panel Surface Anti-glare, 3H Light Source 50,000 hrs. (typ) VIDEO INPUT Analog RGB Analog (75 ohms, 0.7 / 1.0 Vp-p) Digital DVI-D (TMDS, 100ohms, with HDCP), HDMI Frequency Fh: 24-83kHz, Fv: 50-76Hz Sync Separate Sync / Composite Sync / SOG COMPATIBILITY PC VGA up to 1920×1080 non-interlaced Mac®* Power Mac, up to 1920×1080 CONNECTOR Analog 15-pin mini D-sub Digital DVI-D (TMDS, 100 ohms, with HDCP) / HDMI Power 3-pin AC plug (CEE22) Audio 3.5 mm Audio line-in / 3.5 mm Audio line-out AUDIO Speakers 2 x 1.5 watt with SRS WOW sound* POWER Voltage AC 100-240V (Universal); 50/60Hz (Switch) Consumption 40 (typ.) ERGONOMICS Tilt 20° ~ -5° CONTROLS Basic 1, 2, power, down, up OnView® Auto image adjust, Contrast/Brightness, Input select: D-SUB, DVI, HDMI PC, HDMI AV, Audio adjust: Volume, mute, Color adjust: sRGB, 9300K, 7500K, 6500K, 5000K, user color [R, G, B], Information, Manual image adjust: H/V position, Horizontal size, fine tune, sharpness, dynamic contrast, response time, aspect ratio, display mode, Eco mode, Setup menu: language, resolution notice, OSD position, OSD timeout, OSD background, sleep, Memory recall OPERATING CONDITIONS Temperature 32-104°F (0-40°C) Humidity 20 - 90% (non-condensing) DIMENSIONS
(WxHxD) Physical with stand 20.2" x 16.1" x 8.2" (513mm x 410mm x 208mm) Physical without stand 20.2" x 13.0" x 2.2" (512mm x 330mm x 56mm) WEIGHT Net with stand 9.1 lbs (4.1 kg) VESA® MOUNT 100mm x 100mm REGULATIONS UL, CUL, FCC-B (ICES), CB, CE, CES-003B, VCCI , ERGO (MPR II, ISO 13406-2), TUV-S, NOM, GOST-R, HYGIENIC (20 copies), Energy Star, CCC, BSMI, PSB, C-TICK, MIC (KCC), SASO, WEEE, RoHS, Ukraine, EPEAT Silver RECYCLING/DISPOSAL The lamp in this product contains mercury. Please dispose of in accordance with local, state and federal laws. PACKAGE CONTENTS ViewSonic VX2260wm LCD, VGA cable, DVI cable, Audio cable, Power cable, Quick Start Guide, ViewSonic Wizard CD POWER MANAGEMENT Meets ENERGY STAR® standards WARRANTY Three-year limited warranty on parts, labor and backlight
Moga2x berguna...
lupa g ta kasih pelindung LCD, dah 2 minggu g balek ke rumah ( anak kos ) eh dapet kejutan kaya gitu..
