Masalah pada printer laser HP1020
  • Masalah pada printer laser HP1020
    mohon bantuan master-master forum
    Dikantor gue menggunakan printer laser HP1020 monocrome
    printer ini dah lama kira2 1 tahunan, terus dah sering refil,belom pernah ganti toner
    printer ini sekarang ngadat, setiap kali ngeprin keluar kertas kosong dan keluar status message "the HP laserjet 1020 is out of paper or misfet"
    apa penyebabnya?
    terus gimana solusinya?
    thanks
    Re: Tanya Mengatasi masalah pada printer laser HP1020
    apa penyebabnya?
    thanks
    HP 1010,1015,1020 printers error light
    Control Panel Lights
    HP laserjet printers,
    HP 1010,1015,1020 series
    The printer displays status and errors through patterns of the Go, Ready, and Attention lights.If any lights are blinking, the error is usually resolvable. In all cases:
    1. If the error pattern occurs when printing, try pressing the Go button to continue.
    2. Ensure that the print cartridge is properly installed and the print cartridge access door is closed.
    3. Cycle the printer power.
    Control Panel Light Patterns
    The lights on the printer, from back to front, are the Go, Ready, and Attention lights. Each light can be on solid, or blinking. All three can blink in sequence (cycling). In this document, the states of the lights are represented as follows:
    Initialization/Startup
    In the Initialization/Startup State, the lights cycle one after another in a front to back pattern (the "landing lights" pattern). Pressing buttons has no effect.
    Re-Config Initialization
    When a power-on function is activated (i.e., Cold-Reset or NVRAM-Initialization) the lights cycle as in the startup state.Pressing buttons has no effect.
    Ready - The device is ready with no job activity
    In the Ready state, the Ready light is on and the Go and
    Attention lights are off. In this state, the printer has no errors
    and is ready to receive data.Pressing Go prints a demo page.
    Processing data - Device is processing or receiving data
    In the Data Processing state, the Ready light is blinking and
    the Go and Attention lights are off. Pressing Go cancels the
    current job without printing another non-picked page. The
    printer returns to the Ready state after the job has been
    canceled.
    Job Cancel
    In the Job Cancel state, all the lights cycle. Pressing Go has no
    effect. Once the job cancel process is complete, the printer
    goes to the Ready state.
    Continuable error
    In the continuable error state,the Go light is on, the Ready light is off, and the Attention light is blinking. Press Go to attempt to recover from the
    error and continue printing. If the printer recovers from the error, it will move to the Processing data state and complete the job. If the recovery fails, the device will return to the continuable error state. This state can be reached in the following circumstances:
    ● Manual Feed
    ● Out of paper for the specified tray
    ● General continuable error
    ● Memory overflow (error 20) / memory full. Note: PCL only.
    ● Temporary engine error (41.x errors)
    ● I/O error (22 error) / Buffer flow error Note: Parallel only.
    ● I/O data error (40 error) (Bad Connection) Note: Parallel only.
    ● Memory configuration error
    ● Personality/Job related error
    ● Fuser high temperature (50.011 error)
    Note
    The HP laserjet printer 1010 product series does not have paper out sensors.When the printer goes to a continuable error state because its out of paper, the user the will need to reload paper and press Go to continue. No secondary error information is provided to the user from the lights.
    Attention State
    In the Attention state, the Attention light is blinking and the Go and Ready lights are off.This state can be reached in the following circumstances:
    ● Paper tray is empty
    ● Door open
    ● Toner Cartridge Missing
    ● Paper jam/ Tray Misfeed
    Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases.
    It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
    Note
    When the printer is in an Attention state because the paper tray is empty, the user
    must reload paper and press Go.
    Fatal Error
    While in the fatal error state, all three LED's are on continuously. Pressing Go
    displays the secondary error information for the fatal error, and releasing the button(s) will cause the device to return to the initial "fatal error" state.
    Cleaning Page
    The cleaning page is activated
    using the Toolbox application.
    Button presses are ignored
    during cleaning mode
    Sleep Mode
    From the customer's
    perspective Sleep mode is the
    same as Ready mode
    Fatal Errors
    If the printer displays all lights on solid and the error is not resolved by cycling the power,
    then a fatal error has occurred. The two identifiable errors are failed communication between the formatter and the engine and a failed fuser. If neither of these are identified using the following procedure, replace the printer.
    1. Press and hold the Go button and the printer will display a secondary error pattern.
    2. If the secondary error pattern is the Attention light on, the formatter and engine are
    not communicating.
    ● Check the ribbon cable between the formatter and ECU and all other connections.
    ● If error persists, replace the ECU.
    ● If error persists, replace the printer.
    3. If the secondary error pattern is the Go and Ready lights on,
    the fuser (fixing assembly) has failed and must be replaced.
    silahkan dibaca, soalnya lebih jelasnya anda yang tau.
      Re: Masalah pada printer laser HP1020
      Pake bahasa planet... ra mudeng aku
        thanks bro masukannya
        tapi masih aja,kalo power di hidup matikan printer akan normal lg
        terus kalo dipake ngeprin kertas keluar tapi kosong dak ada tulisan
        terus ngebling lagi "out paper" lg,padahal kertas masih ada.
        kalo manual yg indonesia ada dak?
          @mystrodesign: bahasa inggris aja gw susah paham, lha ini dicampur bahasa teknologi.. makin berasa bego
          singkatnya aja bro dalam bahasa indonesia, moga2 bisa jadi pencerahan juga buat yg laen.
            sory bro buku panduannya adanya bahasa inggris, tetapi intinya itu kode error printer hp laser tipe diatas, kalau emang ternyata tidak ada blink berarti yang ada masalah tinggal pc dan kabel data sebagai penyambung.
            kalau printer ke detek berarti kabel port ok berarti masalah tinggal di pc.
            1. coba unistal driver trus restart
            2. install driver baru lagi
            3. kalau ini tidak menyelsaikan msalah ada kemungkinan
            anda harus update driver buat printer tersebut.
            note: saya coba googling untuk cari solusi buat masalah in dan ternyata hampir semua masalah hp 1020 kalau g spool nya, blank print outnya. dan anehnya the answer only coba hubungi pihak hp yang berwenang.
              @dedekimut
              coba self test nya dijalanken bro. Kalo self test saja gagal, dugaan error ada di printer.
