[Link] Recommended Tools For Case Modding
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: [Link] Recommended Tools For Case Modding
    106°46'BT,6°19'LS
    gue nemu blog yg merekomendasikan alat yg digunakan untuk modding beserta link cara penggunaan, belinya dimana, dsb...
    I'm asked frequently by those who have just starting Modding "What do I need for tools?"
    What I've done is list the most common tools used at MNPCTECH.COM for modding cases with brief description.
    Other than a Greenlee knock-out punch I'm always asked about, I've only focused on affordable hand tools and power tools.
    THINK SAFETY FIRST, Safety Glasses should be your first purchase!
    Respirator Mask with canister filters Use when sanding, painting or using any hazardous chemicals
    Rotary Cutting Tool
    The most versatile tool for case modding. You can cut plastics, metals,
    grind and polish. Dremel brand is most popular. Black & Decker and
    Craftsman versions are also popular.
    & more
    selengkapnya di: http://blogs.pcapex.com/mnpctech/blo...s_case_modding
    Oct 2005
    Re: [Link] Recommended Tools For Case Modding
    gambar ke 2 tuh mau ngapain yah?? buset deh
    WITH GREAT POWERS COMES GREAT RESPONSIBILITY
    Bandung . . . .
    make masker supaya pas motong secc/alu serbuknya biar gak kehirup
    Sep 2007
    Quote Originally Posted by andhee View Post
    tinggal pake jaket, helm, sama rompi item udah kek anggota S.W.A.T. deh
    kumplit pake masker segala
    *btw gambar #2 paling keren, sudah ada 3 komentar sejauh ini
    sorry
    wedew, cool boss
    cocok buat yang sering modding,
    kalau cuma buat sekali modding bakalan tekor, hehe
    itu bill owen dari mnpc tech ya. pake resp protector perlu kok. bwat ngecat apa lagi.
    106°46'BT,6°19'LS
    Quote Originally Posted by zhock View Post
    he eh... kalo ngecat pasti lah... yg bahaya tanpa disadari, serbuk asbes dari sanding disc.. ini sebenernya bahaya lho...
    balikpapan
    kalo diganti masker buat naik motor itu bisa gak yah?
    masker motor kan lebih susah bernapasnya? :beer:
    yup. gw biasa kalo gi ngamplas metal jg pake resp mask.. ga kebayang kalo ampe paru2 gw kmasukan serbuk2 metal.. dari ngamplas hii..
    Feb 2008
    bogor, jawa barat
    gw kebetulan ga da doku buat beli respirator ny , jd gw make teknik wet sanding aja (ngaplas campur pake air ) jd kan aman tuh ga ada debu yg melayang ke paru-paru cuma aga lama, tapi hasilnya memuaskan , gw dah pernah nyoba pake amplas no 1200cw cuma lama nya minta ampun, jd gw langsung pake yg no 600, trus no 1000 bersih dah semua tinggal pilox pake rjlondon no.6 (silver red) Rp.16.000,00,- dua kaleng, ga pake glos jg dah bagus mengkilap ky mobil honda jazz ....
    kalo bwat ngamplas sisa cat pake wetsanding emank bagus hasilnya smooth bro.. tapi kalo mo bwat hairline ato ngmplas sisa material.. ga bs wetsanding.. , toh untuk ngamplas sisa cat pun ga bs wet sanding smua. pas final aj baru di wetsand kalo ga kelamaan kerjanya + capek hehe..
