wew, lg isenk isenk liat HSF tnyata ad klasemen baru neeh..
stelah sekian lama SunBeam mnduduki posisi teratas, akhirnya skrg trgantikan posisinya oleh Titan TTC-NK85TZ
modelnya ky gini :
Ini Fan nya :
Ini perabotannya :
Model No : ‧TTC-NK85TZ
For AMD Socket AM2+/AM2/940/939/754/K8
For Intel Socket 775/1366
Features :
‧Universal design: compatible with Intel LGA 775/1366 and AMD K8/AM2
‧PWM intelligent controller: automatically adjust fan to provide wonderful balance between performance and rumble generated from CPU
‧12cm large fan : cover whole area for system cooling + Superior silent performance at 17dBA only
‧Heat Pipe Direct Touch: provide the maximum heat conductivity and draw heat away immediately
‧Unique fin design: reduce air resistance to enhance cooling performance
CPU Support :
‧Second-Generation Opteron™ upto~1222 SE/1222
‧Third-Generation Opteron™ upto ~1356
‧Athlon64 upto~4000+/LE-1620
‧Athlon64FX upto~FX-74
‧Athlon64 X2 upto~6400+/BE 2400/4850e
‧AMD Phenom™ X 3 upto~8750
‧AMD Phenom™ X 4 upto~9950
‧Sempron upto 3800+/LE-1250
‧Core2 Duo upto~E8600
‧Core2 Extreme upto~QX9770 /X6800
‧Core2 Quad upto~Q9650
‧Pentium D upto~960
‧Pentium Dual Core upto~E5200
‧Pentium Extreme upto~965
‧Pentium 4 upto~672
‧Pentium 4 Extreme upto~3.73G Hz
‧Celeron upto~365
Specifications :
Outline Dimension 156 x 124 x 107mm
Fan Dimension 120 x 120 x 25 mm
Rated Voltage 12V DC
Rated Cunent 0.32A
Power Consumption 3.84W
Rated Speed 800~2200 RPM ±10%
Airflow 33.2~78.41CFM
Static Pressure 0.02~ 0.11 InchH2O
Noise Level <17.2 ~ <39dBA
Rotation Direction Clockwise
No. of Pole 4 Pole
Bearing Type Z-axis Bearing
Life Time 60,000 HOURS
Packing :
1CTN(PCS) 8
N.W.(KGS)
G.W.(KGS)
MEAS'T(CUFT) 2.04
Ini Fan nya :
