Berikut petikan press release-nya
Corsair Launches Hydro Series H70 CPU Cooler
– Builds on success of the award-winning H50 by improving airflow, water block, and heat dissipation capacity –
Fremont, California — August 4, 2010 — Corsair®, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the Corsair Hydro Series™ H70 ultra-performance CPU cooler. This CPU cooler is designed to provide an extremely efficient cooling solution for CPUs from Intel® and AMD.
The Hydro Series H70 CPU cooler is an evolution of the award-winning Hydro Series H50, with several significant upgrades that enable it to deliver even greater cooling performance. These upgrades include a double-thickness (50mm) radiator with higher heat-exchanging capacity and a pump/cold plate unit with increased efficiency. The H70 also features two 120mm speed-switchable cooling fans in a push-pull configuration to provide increased airflow at low noise levels.
"Thanks to the H70, you no longer need a fin array the size of a small shoebox to cool aggressively overclocked CPUs," stated John Beekley, VP of Technical Marketing at Corsair. "The H70 stands toe-to-toe with any CPU cooler on the market, and does it with less noise, easier installation, and the support of nearly every ATX-compatible case."
Like the wildly popular H50, the Hydro Series H70 provides the benefits of water cooling in a sealed and pre-filled unit, with no maintenance required. The low profile cold plate is extremely space efficient, and is very low in mass compared to heat pipe based solutions, putting less stress on the system's motherboard. The H70 includes mounting hardware for most common AMD and Intel CPUs, and unlike some competitive CPU coolers, includes all necessary fans for high performance operation.
Images of the Hydro Series H70 can be found here.
For more information on Corsair Hydro Series CPU coolers, please visit: http://www.corsair.com/products/casescooling_home.aspx.
The Corsair Hydro Series H70 CPU Cooler is available immediately from Corsair's worldwide network of authorized distributors and resellers. It is supplied with a two year warranty, and is backed by Corsair's legendary customer service and technical support.
About Corsair
Founded in 1994, Corsair supplies high performance products purchased primarily by PC gaming enthusiasts who build their own PCs or buy pre-assembled customized systems. The company's award-winning products include DRAM memory modules, USB flash drives, power supply units, solid-state drives, cooling systems and computer cases.
Gambar paket penjualannya :
Sedikit test cepat :
UPDATE : Barang Ready Stock dengan harga sekitar $110++
Bambang
DTG
