Minta saran Water Kuling doooong....
Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 10 of 74
Thread: Minta saran Water Kuling doooong....
    localhost
    Hmm kyana udah waktuna gw berpindah dari air kuling ke water kuling. tapi gw maunya semua include. jadi mulei dari cpu, vga n chipset bisa pake water kuling..
    ada saran gak pake apah n yg paling penting, harga bro harga.. it's all about the money biar nyonya gak ngomel
    thanks yah..
    Tanjungpandan
    Re: Minta saran Water Kuling doooong....
    use search function
    My authentic japanese name is 石丸 Ishimaru (round stone) 由希 Yuki (significant hope).
    mau yg custom/lgsg watercooling kit?Kalo watercooling kit,lo bs coba bigwater 745,g pake di a64 venice,vcore default,suhunya 23,fulload 28an,lumayan kok.Kalo custom bs coba pk fitur search,buat cari2,dl ada yg bkn thread serupa.Salam
    zion
    Coba nih liat ada review baru di XBitlabs, disini:
    http://www.xbitlabs.com/articles/coo...ercooling.html
    di xtreemsys jg banyak...hv nice browsing d
    tapi gw compare sana-sini TT BW745 paling competitive price n performance, dibandingin waterchill lho
    >>> NeXt rIg : E6600 + 975X + DDR2 1066
    "Every New Technology is a Milestone for Our Life, Just Dont Get Caught In Between"
    Quote Originally Posted by rk c00l
    yoi.... pake bigwater thermaltake aja... btw klo mau ma vganya kira2 1,5jt kurang lah...
    Water cooling starter IMO
    Water Pump: bisa dari pompa aquarium, submersible atau pompa khusus untuk WC (low end: L30, medium: DD D5, high end: Aqua 50z)
    Radiator (Low End: Black Ice Pro, Medium: Black Ice Extreme, High End: ThermoChill 2.0)
    CPU WaterBlock (Low end: DD TDX, Medium: Swifttech Storm R.2, High End: Whitewater MP-05 PRO LE)
    Reservoir (optional), Reservoir hanya bertujuan untuk kemudahan penambahan/pengisian air, kalo nggak punya res bisa aja pake t line (cabang T) terus ujungnya di"sumpel"
    the best configuration IMO:
    pump>radiator>reservoir>cpu>pump
    wuih.... khurious2000 pake custom ya bang?? whueleh... asyik jg kayanya...
    kalo pake pompa aer mancur yang kecil lucu gak yah?? 150rb tuh... tinggal bli yang lain2nya.
    Feb 2006
    Tangerang
    Quote Originally Posted by khurios2000
    kira2 bikin gini abis berapa bro? yg low end aja..
    paket yg paling murah tapi ok tu pake apa ya bro?
    Quote Originally Posted by monarch_master
    yoi, custom, low end aja,
    kalo pake pompa air mancur bisa aja asal nozzlenya bisa dipasangin selang.
    Quote Originally Posted by vboar
    DD TDX = 50
    Black Ice Extreme = 40
    Hydor L30 = 30
    Tubing = 10
    ---------------130
